I am running asynchronous application in batch process mode.
When I try to connect the application with the existing creo session using ProEngineerConnect, it is returning error PRO_TK_CANT_MODIFY.
I have set the environment variable PRO_COMM_MSG_EXE also.
Including the file name in the variable, made it to connect.
Earlier I used only the path of the exe. But now I am using the full path with the exe name also.
Thanks Tomas for the help.
How did you set the PRO_COMM_MSG_EXE variable? Is it set correctly?
Is nmsd.exe process running? Can you read anything from the trail file?
I have set the PRO_COMM_MSG_EXE as a system variable.
From cmd it is able to get its value.
Also nmsd.exe and pro_comm_msg.exe processes are running.
API returns 'PRO_TK_CANT_MODIFY'.
I have tried by disable firewall settings also.
You are welcome. Yes, you have always to use the full path.
