Hi Mark,
I updated already three JLink applications to Creo 2 and had no real problems.
I followed the description from JD Felco, see here: http://www.felcosolutions.com/JLinkRibbon.pdf.
I had only one issue with a tool that regenerates the modelin Creo. If the config option regen_failure_handling is not set to resolve_mode, the regeneration fails.
A other application changes the frame on a drawing and moves tables on the drawing, I was able to reuse the old code to change the frame and find/move the tables.
Michael Holzwarth
Global IT PDP Modeling Solutions Region 2
John Deere GmbH & Co. KG
John Deere Werk Mannheim
John-Deere-Str. 90 • 68163 Mannheim • Germany
