What needs to be modified in the existing VB Program syntax to refer
assembly drawing since original API Kit was developed to refer part model
drawing.
Note: API Kit is working well for part model drawings. Refer below for the
coding which created to read part model in the drawing.
DimasyncConnection As IpfcAsyncConnection = Nothing
Dim conn As CCpfcAsyncConnection
Dim session As IpfcBaseSession
Dim model As IpfcModel
Dim assembly As IpfcAssembly
Dim tableOwner As IpfcTableOwner
Dim tables As IpfcTables
Dim table As IpfcTable
conn= New CCpfcAsyncConnection
asyncConnection = conn.Connect("", "", ".", 5)
session = asyncConnection.Session
model = session.CurrentModel
assembly = model
tableOwner = assembly
tables = tableOwner.ListTables
table = tables.Item(0)
Here is the sample code. I am trying to chenge the assembly drawing.
I am getting some exception. I have attached the exception.
