I'm working on an Excel VBA tool that imports a lot of pvz files into Creo and saves them as .asm's. Works like a charm when I do this by hand (obviously, these are not real CAD models but facet geometry).
If I run the code below, I get a Type Mismatch error on te line starting with Set Model = session.ImportNewModel...
The weird thing is Creo actually imports the pvz, because if I do File > Open > In Session, I can see and open my example asm (testjaap.asm).
Does anyone know how I can get the model opened?? I tried all kinds of things, but nothing works so far...
Thnx!
Jaap
code:
Sub import_pvzs()
Dim asynconn As New pfcls.CCpfcAsyncConnection
Dim conn As pfcls.IpfcAsyncConnection
Dim session As pfcls.IpfcBaseSession
Dim model As IpfcModel
Set conn = asynconn.Connect("", "", ".", 5)
Set session = conn.session
Set model = session.ImportNewModel("C:\local\test_buildassyfromtextfile_transformation_matrix\TEST_ASSY_A0120069, Box Packer\A0133910, CRASH CAMS - Cabinet Module.pvz", EpfcNewModelImportType.EpfcIMPORT_NEW_PRODUCTVIEW, EpfcModelType.EpfcMDL_ASSEMBLY, "testjaap", Nothing)
conn.Disconnect (2)
End Sub
Strange. Your code worked for me.
Ideas:
sample code for STEP import...
Dim mdl As IpfcModel = session.ImportNewModel(
"D:\WorkDir\Example\heatSink.step",
EpfcNewModelImportType.EpfcIMPORT_NEW_STEP,
EpfcModelType.EpfcMDL_PART,
"MyNewPart",
Nothing)
mdl.Display()
Thnx for your reply!
Unfortunately, this seems to be the syntax for Visual Studio, not for Excel.
In Excel I'm not allowed to combine the Dim and the command. And if I split the line in:
Set mdl = session.ImportNewModel("C:\local\test_buildassyfromtextfile_transformation_matrix\TEST_ASSY_A0120069, Box Packer\A0133910, CRASH CAMS - Cabinet Module.pvz", EpfcNewModelImportType.EpfcIMPORT_NEW_PRODUCTVIEW, EpfcModelType.EpfcMDL_ASSEMBLY, "testjaap", Nothing)
I get the Type Mismatch error, even though session.ImportNewModel is an IpfcModel according to the documentation (and according to your example).
Anyone have a clue how to cope with these kind of situations in VBA Excel? It's not the first time Excel bugs me with object type problems...
Thnx!
I was able to get this to work in Excel VBA:
Set mdl = session.ImportNewModel("C:\Users\Public\Documents\testasm.pvz", EpfcNewModelImportType.EpfcIMPORT_NEW_PRODUCTVIEW, EpfcModelType.EpfcMDL_ASSEMBLY, "mynewpart", Nothing)
'Make sure model is displayed and active.
Dim oWindow As pfcls.IpfcWindow
Set oWindow = session.GetModelWindow(mdl) 'If no model was open in Creo session, model automatically displays.
If oWindow Is Nothing Then Set oWindow = session.CreateModelWindow(mdl) 'Create window before displaying model
mdl.Display
oWindow.Activate 'Active window with new model in it
The "mynewpart" name doesn't seem to work when importing PVZ assemblies though.
Thnx!
I tried your example, but on my PC I still get the exact same Type Mismatch error.
I also tried with a single part (changing EpfcMDL_ASSEMBLY to EpfcMDL_PART), but that gives the Type Mismatch error, too.
Here's my complete code:
Sub import_pvzs()
'session.ChangeDirectory ("C:\local\test_backup")
Set mdl = session.ImportNewModel("C:\local\test_assy.pvz", EpfcNewModelImportType.EpfcIMPORT_NEW_PRODUCTVIEW, EpfcModelType.EpfcMDL_ASSEMBLY, "test_assy1", Nothing)
mdl.Display
'session.CurrentModel.Save
conn.Disconnect (2)
End Sub
Can it be that there's something wrong in the configuration of Excel?!
Thanks!
maybe version of Creo + version of Excel affects the result.
Ideas:
thanks again!
Problem solved... I tried the code on a computer running Creo 6, and it worked.
Then, I went back to the PC running Creo 4 (our current version), and saw that Excel had references to both the Creo 2 and Creo 4.
After unchecking Creo 2.0 in the list all worked fine.
I find this reference list in Excel weird and confusing...
All in all a happy end.
