Hello everyone,
Does anyone know how to export a prt or drawing to dxf using VBA Excel? I got other activities such as changing dimensions and creating a drawing, but this one is having difficulty.
1. "Creo VB API Example code to export a part model to 3D DXF Format in Creo Parametric ": https://www.ptc.com/en/support/article/CS247215
Quote: "Creo Parametric VB API Users may refer to below provided example C# function":
// Input arguments
// strFile = Full absolute path to the Creo Parametric part file (example: C:\Temp\dxf_export.prt)
// strDXF = DXF output file name
// Note: Passing strFile length beyond 66 chars would lead to pfcExceptions::XStringTooLongthrow.
// To use longer file paths beyond 66 char length, please see article CS95056
// conn = Creo Asynchronous Connection object.
static internal bool ExportToDXF3D(string strFile, string strDXF, IpfcAsyncConnection conn)
if (string.IsNullOrEmpty (CreoPath)) return false;
IpfcModel model = null;
try {
var session = conn.Session as IpfcBaseSession;
var dxfexp = (new CCpfcDXF3DExportInstructions ().Create ()) as IpfcDXF3DExportInstructions;
int type = (int)EpfcModelType.EpfcMDL_PART;
var modelDesc = new CCpfcModelDescriptor ().Create (type, strFile, null);
// modelDesc.Path = "full directory path where the part file exists"
model = session.RetrieveModelWithOpts (modelDesc, new CCpfcRetrieveModelOptions().Create ());
//model.Display();
try {
var exi = dxfexp as IpfcExport3DInstructions;
var triangOptions = (new CCpfcTriangulationInstructions().Create(0.10000, 0.500000)) as IpfcTriangulationInstructions;
triangOptions.StepSize = 0.5;
exi.set_TriangulationOptions(triangOptions);
var new_exi = exi as IpfcExportInstructions;
model.Export (strDXF, new_exi);
} catch (COMException ex) {
var ex2 = Marshal.GetExceptionForHR (ex.ErrorCode);
Console.WriteLine (ex2.Message);
return false;
return true;
} finally {
try { if (model != null) model.Erase (); } catch { }
conn.Close ();
return false;
2. "Example code to export (Save As) a drawing file to PDF format through Creo Parametric VB API": https://www.ptc.com/en/support/article/CS141963
Quote: "Example code to export Active drawing model to PDF format with Stroke All Fonts, Monochrome and do not check Open file in Acrobat Reader options defined":
Sub Main2()
Dim asynconn As New pfcls.CCpfcAsyncConnection
Dim conn As pfcls.IpfcAsyncConnection
Dim CreoSession As pfcls.IpfcBaseSession
Dim CreoCurrentModel As pfcls.IpfcModel
'Make an asynchronous connection with Pro/ENGINEER
Set conn = asynconn.Connect("", "", ".", 5)
'Get the current session
Set CreoSession = conn.session
'Show the current Working Directory
MsgBox "This is the current Working Directory: " & vbCrLf & CreoSession.GetCurrentDirectory
Set CreoCurrentModel = CreoSession.CurrentModel
'Show the name of the Pro/E Model in a messagebox
MsgBox "Model name = " & CreoCurrentModel.FullName
Dim oWindow As IpfcWindow
Set oWindow = CreoSession.GetModelWindow(CreoCurrentModel)
'Activate the new window before printing (Good practice)
oWindow.Activate
Dim PDFExportInstrCreate As New CCpfcPDFExportInstructions
Dim PDFExportInstr As IpfcPDFExportInstructions
Set PDFExportInstr = PDFExportInstrCreate.Create
Dim PDF_Options As New pfcls.CpfcPDFOptions
' Set Stroke All Fonts PDF Option
Dim PDFOptionCreate_SAF As New CCpfcPDFOption
Dim PDFOption_SAF As IpfcPDFOption
Set PDFOption_SAF = PDFOptionCreate_SAF.Create
PDFOption_SAF.OptionType = EpfcPDFOptionType.EpfcPDFOPT_FONT_STROKE
Dim newArg_SAF As New CMpfcArgument
PDFOption_SAF.OptionValue = newArg_SAF.CreateIntArgValue(EpfcPDFFontStrokeMode.EpfcPDF_STROKE_ALL_FONTS)
Call PDF_Options.Append(PDFOption_SAF)
' Set COLOR_DEPTH value (Set EpfcPDF_CD_MONO to have Black & White output)
Dim PDFOptionCreate_CD As New CCpfcPDFOption
Dim PDFOption_CD As IpfcPDFOption
Set PDFOption_CD = PDFOptionCreate_CD.Create
PDFOption_CD.OptionType = EpfcPDFOptionType.EpfcPDFOPT_COLOR_DEPTH
Dim newArg_CD As New CMpfcArgument
PDFOption_CD.OptionValue = newArg_CD.CreateIntArgValue(EpfcPDFColorDepth.EpfcPDF_CD_MONO)
Call PDF_Options.Append(PDFOption_CD)
' Set PDF EpfcPDFOPT_LAUNCH_VIEWER(Set FALSE Not to Launch Adobe reader)
Dim PDFOptionCreate_LV As New CCpfcPDFOption
Dim PDFOption_LV As IpfcPDFOption
Set PDFOption_LV = PDFOptionCreate_LV.Create
PDFOption_LV.OptionType = EpfcPDFOptionType.EpfcPDFOPT_LAUNCH_VIEWER
Dim newArg_LV As New CMpfcArgument
PDFOption_LV.OptionValue = newArg_LV.CreateBoolArgValue(False)
Call PDF_Options.Append(PDFOption_LV)
'Set Output PDF File Name
PDFExportInstr.FilePath = "D:\" & CreoCurrentModel.FullName & ".pdf"
PDFExportInstr.Options = PDF_Options
CreoCurrentModel.Export PDFExportInstr.FilePath, PDFExportInstr
'Disconnect with Pro/ENGINEER
conn.Disconnect (2)
'Cleanup
Set asynconn = Nothing
Set conn = Nothing
Set session = Nothing
Set oModel = Nothing
End Sub
// Input arguments
try {
//model.Display();
try {
return false;
return true;
} finally {
conn.Close ();
return false;
Sub Main2()
oWindow.Activate
conn.Disconnect (2)
'Cleanup
Set conn = Nothing
End Sub
Thanks, I will try to adapt the C# code to VBA.
