Weblink (CreoJS) Table.SetText Not Working
  • July 11, 2024
  • 999 views
Has anyone had luck with table.settext?  For me it's breaking and a try/catch isn't throwing the error message.  The table is generating up to this point.
I know it's breaking because if I moved the mergeregion after the settext, that doesn't work, and the rest of my code isn't running either.
Any help would be appreciated!  Thanks!
var dwgTable = drawing.CreateTable (tabinstrs);
var topLeft = pfcCreate ("pfcTableCell").Create (1, 1);
var bottomRight = pfcCreate ("pfcTableCell").Create (1, 5);
dwgTable.MergeRegion (topLeft, bottomRight, null);
try {
dwgTable.SetText(1, , "CONN NAME PART NUMBER");
} catch (err) {
  alert("Error setting text in table cell");
Best answer by AH_10565398
I resolved this myself.  I found the writetextincell function from the JS example.
function writeTextInCell(table /* pfcTable */, row /* integer */,
  col /* integer */, text /* string */)
var cell = pfcCreate ("pfcTableCell").Create (row, col);
var lines = pfcCreate ("stringseq");
lines.Append (text);
table.SetText (cell, lines);
AH_1056539812-AmethystAuthorAnswer
