how to create extrude feature in part file
Aravind_98
Hi team,
I've one doubt regarding to create a part file with extrude feature. just i need to create one simple extrude(rectangle) using Protoolkit.
if anybody knows pls help me.
ProError action_cb()
ProError err;
ProSolid mdl;
int window_id;
ProName Mdl_name;
string str = "Extrude";
ProStringToWstring(Mdl_name, (char*)str.c_str());
err = ProSolidMdlnameCreate(Mdl_name, PRO_MDLFILE_PART, &mdl);
err = ProWindowCurrentGet(&window_id);
err = ProWindowActivate(window_id);
return err;
extern "C" int user_initialize()
ProError err;
uiCmdCmdId action_id;
const char* msg_file = "Message.txt";
string str = msg_file;
ProFileName file_name;
ProStringToWstring(file_name, (char*)str.c_str());
err = ProMenubarMenuAdd((char*)"Model", (char*)"Model", (char*)"help", PRO_B_TRUE, file_name);
err = ProCmdActionAdd((char*)"test", (uiCmdCmdActFn)action_cb, uiProeImmediate, NULL, PRO_B_FALSE, PRO_B_TRUE, &action_id);
err = ProMenubarmenuPushbuttonAdd((char*)"Model", (char*)"Create", (char*)"Create", (char*)"Create", NULL, PRO_B_TRUE, action_id, file_name);
return err;
extern "C" void user_terminate()
remy
(To:Aravind_98)
Hi
From a glance it looks like the code you shared  is a button that creates an extrude (but i did not read it in details).
After searching our knowledge base, most of the example rely on Element tree :
https://www.ptc.com/en/support/article/CS279089
https://www.ptc.com/en/support/article/CS261744
https://www.ptc.com/en/support/article/CS402131
this article gives a sample code shipped with Creo :  <creo_toolkit_loadpoint>\protk_appls\pt_examples\pt_feature\TestExtrude.c
remy
(To:Aravind_98)
Hi
Aravind_98
(To:remy)
hi @remy
Thank you.
