tell the some example
Hi Keerthana,
Tthe "text" folder can actually be created almost anywhere on your machine.
You should be able to mimic the setup of the examples. For Pro/TOOLKIT, check out the "protk_install_example" that is located in the "protoolkit" subfolder of your installation.
Here are some PTC support docs that may also help:
If you need help with this, feel free to send me a PM. I'd be happy to try to help.
James Sullivan
