Hi everybody,
I was trying to use j-link to assembly a componet using csys references. But I got some problems.
I appreciate if everyone can help me.
would like to know how can I assembly a component model like a part
in a sub-assembly using csys as reference.
I have a main assembly and a sub-assembly. So I have to assembly a componet
in the sub-assembly using csys references from the main assembly.
Tree:
Main_Assembly.asm
mainCSYS
Part1.prt partCSYS1 partCSYS2
SubAssembly.asm subassyCSYS NEW_Assymbly_Part.prt newpartCSYS
I have to assembly the NEW_Assymbly_Part.prt in the assembly
SubAssembly using as Componet Reference the csys newpartCSYS
(in SubAssembly) and using as Assembly Reference the csys partCSYS2;
Please, How can I do this with j-link.
import com.ptc.cipjava.intseq;
import com.ptc.cipjava.jxthrowable;
import com.ptc.pfc.pfcAssembly.Assembly;
import com.ptc.pfc.pfcAssembly.ComponentPath;
import com.ptc.pfc.pfcAssembly.ExplodedState;
import com.ptc.pfc.pfcAssembly.pfcAssembly;
import com.ptc.pfc.pfcCommand.DefaultUICommandActionListener;
import com.ptc.pfc.pfcComponentFeat.ComponentConstraint;
import com.ptc.pfc.pfcComponentFeat.ComponentConstraintType;
import com.ptc.pfc.pfcComponentFeat.ComponentConstraints;
import com.ptc.pfc.pfcComponentFeat.ComponentFeat;
import com.ptc.pfc.pfcComponentFeat.pfcComponentFeat;
import com.ptc.pfc.pfcGlobal.pfcGlobal;
import com.ptc.pfc.pfcModel.Model;
import com.ptc.pfc.pfcModel.ModelDescriptor;
import com.ptc.pfc.pfcModel.ModelType;
import com.ptc.pfc.pfcModel.pfcModel;
import com.ptc.pfc.pfcModelItem.ModelItem;
import com.ptc.pfc.pfcModelItem.ModelItemType;
import com.ptc.pfc.pfcModelItem.ParamValue;
import com.ptc.pfc.pfcSelect.Selection;
import com.ptc.pfc.pfcSelect.pfcSelect;
import com.ptc.pfc.pfcSession.Session;
import com.ptc.pfc.pfcSolid.Solid;
class MenuButtonListener extends DefaultUICommandActionListener {
static String title = "Editor de Parametro"; ParamValue valor;
@Override
public void OnCommand() {
try {
montarComponente("part.prt");
} catch (jxthrowable x) {
x.printStackTrace();
System.out.println("------------------------------------");
public void montarComponente(String componentFilename) throws jxthrowable {
Session session = pfcGlobal.GetProESession();
ModelDescriptor descrFrom = pfcModel.ModelDescriptor_CreateFromFileName("montagem.asm");
Model modelFrom = (Model) session.GetModelFromDescr(descrFrom);
modelFrom = (Solid) session.RetrieveModel(descrFrom);
if (modelFrom == null || modelFrom.GetType() != ModelType.MDL_ASSEMBLY) {
session.UIShowMessageDialog("Reference model is not an assembly.", null);
Assembly assemblyFrom = (Assembly) modelFrom;
ModelDescriptor descrM = pfcModel.ModelDescriptor_CreateFromFileName("test.asm");
Model model = (Model) session.GetModelFromDescr(descrM);
if (model == null) {
model = (Solid) session.RetrieveModel(descrM);
if (model == null || model.GetType() != ModelType.MDL_ASSEMBLY) {
session.UIShowMessageDialog("Current model is not an assembly.",
null);
model.Display();
Assembly assembly = (Assembly) model;
ModelDescriptor descr = pfcModel.ModelDescriptor_CreateFromFileName(componentFilename);
Solid componentModel = (Solid) session.GetModelFromDescr(descr);
if (componentModel == null) {
componentModel = (Solid) session.RetrieveModel(descr);
ComponentFeat asmcomp = (ComponentFeat) assembly.AssembleComponent( componentModel, null); ComponentConstraint constr = pfcComponentFeat.ComponentConstraint_Create( ComponentConstraintType.ASM_CONSTRAINT_CSYS);
ModelItem compItem = componentModel.GetItemByName(ModelItemType.ITEM_COORD_SYS, "PRT_CSYS_DEF"); Selection compSel = pfcSelect.CreateModelItemSelection(compItem, null); constr.SetComponentReference(compSel);
//Assembly that has the model that will be use as reference
/*ModelDescriptor descrFrom = pfcModel.ModelDescriptor_CreateFromFileName("montagem.asm");
if (modelFrom == null) {
Assembly assemblyFrom = (Assembly) modelFrom;*/
ComponentFeat component = (ComponentFeat) assemblyFrom.GetFeatureById(39); ModelDescriptor descComp = component.GetModelDescr(); Solid modelItem = (Solid) session.GetModelFromDescr(descComp); ModelItem asmItem = modelItem.GetItemByName(ModelItemType.ITEM_COORD_SYS, "CS0");
intseq ids = intseq.create(); ids.set(0, component.GetId());
ComponentPath path = (ComponentPath) pfcAssembly.CreateComponentPath(assemblyFrom, ids); path.SetRoot(assemblyFrom); Selection asmSel = pfcSelect.CreateModelItemSelection(asmItem, path); constr.SetAssemblyReference(asmSel);
ComponentConstraints constrs = ComponentConstraints.create(); constrs.insert(constrs.getarraysize(), constr); asmcomp.SetConstraints(constrs, null);
//assembly.Regenerate(null); //session.GetModelWindow(assembly).Repaint(); }
} would like to know how can I assembly a component model like a part
Tree:
Main_Assembly.asm
mainCSYS
@Override
try {
null);
model.Display();
Please explore the "ComponentPath" if you haven't done that already. You will have to paly with component path in order to reach anywhere in tree. And then you have Leaf and Root option to get he CoSys for constructing constraints.
Hope that helps!
Consegiu Marcio?
Att,
