we are having headaches because of the following: Windchill 10 has issues when using 64 bit Java, so PTC told us to only use 32-bit java6.31 only;we also have been told specifically to uninstall the 64-bitJava, because it seems to give problems when both versions are installed.On Build 030 of WF5 this worked ok, but now we are testing WF5 M130 (needed to fix another bug), and now ProE crashes during startup with all kind of java errors (exception ProMenubarmenuPushbuttonAdd(), UIAddbutton etc.), at the moment it loads our J-Link tools. So, we now disabled all of our J-Link tools, but we need these regularly.
Does anyone know how to solve this????
Thanks!
Jaap
Thanks a lotMark! I'll check this on my system.
Kind regards, Jaap
