macro commande
ddubost
7-Bedrock
macro commande
How to stop a macro when you select a value with the right click, then resume the progress of the macro. Example: select a value in the layer tree.
following mapkey works according your needs in Creo 4.0 English.
mapkey lp @MAPKEY_NAMEOpens Layer Properties dialog box;\
mapkey(continued) @MAPKEY_LABELLayer Properties;~ Command `ProCmdLayer_ShowMdlTree` ;\
mapkey(continued) ~ Command `ProCmdMdlTreeShowLyrs` ;@MANUAL_PAUSESelect layer using LMB;\
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `UIT_TRANSLUCENT` `NEED_TO_CLOSE`;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.PHLayerUI.AssyTree` `node0:ANY_LAYER_NAME`;\
mapkey(continued) ~ Command `ProCmdLayer_LayProps` ;\
mapkey(continued) ~ FocusOut `newlayerprops` `LayerNameInput`;
Martin Hanák
17 REPLIES 17
kdirth
20-Turquoise
(To:ddubost)
While recording mapkey select Pause to allow for a manual operation/input.  You can then type in a prompt to tell the user what to do before resuming the mapkey.  Press Resume to continue recording.
ddubost
7-Bedrock
(To:kdirth)
Bonjour
Fonctionne pour une boite de dialogue (Exemple: Esquisse) mais pas pour une sélection clic gauche sur un nom dans l'arbre des couches.
ddubost
7-Bedrock
(To:kdirth)
Hello
Works for a dialog box (Example: Sketch) but not for a left click selection on a name in the layer tree.
@ddubost wrote:
Hello
please describe in detail what your macro should do.
Martin Hanák
ddubost
7-Bedrock
(To:kdirth)
Attached in detail what wishes to achieve
ddubost
7-Bedrock
(To:kdirth)
ddubost
7-Bedrock
(To:kdirth)
ddubost
7-Bedrock
(To:kdirth)
ddubost
7-Bedrock
(To:kdirth)
Martin Hanák
thank you so much It works perfectly.
Practical question. do you have a solution for a direct recovery with left click selection
I am sorry I do not understand term direct recovery with left click selection. Please explain it in detail.
Martin Hanák
thank you for your help and understanding
ddubost
7-Bedrock
(To:ddubost)
Do you have a solution for this topic
Sketch dialog box
I do not understand what you mean with the picture
Martin Hanák
1) I launch the macro
2) I select the layer
3) I click resume
4) The property window is displayed
 Possible
- The macro stops without opening a window -
3) The property window is displayed
3) I click resume
 Possible
it looks like you do not want to select layer name, press RMB and click Layer Properties command from context menu.
Try following procedure:
1.] select layer name
2.] run following macro
mapkey lp ~ RButtonArm `main_dlg_cur` `PHTLeft.PHLayerUI.AssyTree` \
mapkey(continued) `node0:ANY_LAYER_NAME`;~ Command `ProCmdLayer_LayProps` ;\
Martin Hanák
