Dear all,
I am asked to find a solution for a problem:
Company is working with 8 engineers on different projects for different clients, by default people work with WF3. One client wants his project done in WF1 because thats the release they are working with (and they dont want to upgrade yet). This is no problem. Every project has its own directory thats completely separate from other directories.
Problem: on a couple occasions the WF1-client'swork is opend and saved with WF3 by mistake, work cannot be converted to WF1, backup has to be used and lots of work is lost.
How can this be prevented? Is it possible to forbit directories becoming working-directories in a certain version of Pro/engineer??
Kind regards,
Dennis Varkevisser
Hello all,
Dennis,
If you have Pro/Toolkit look up 'ProDirectoryChangePostAction' help section.
Alternatively, using jlink ,look up 'pfcSession.SessionActionListener.OnAfterDirectoryChange'
Another option is to close pro/e session if a user hadwondered into a wrong directory. To do this you could make a short batch/script file to run at Pro/E startup. Use 'FINDSTR' or 'grep' to extract fobidden directory names from the latest trail file and 'TASKKILL' or 'kill' depending on OSto close pro/e sesion.
HIH.
Feliks.
In Reply to Dennis Varkevisser:
Dear all,
Kind regards,
Dennis Varkevisser
______________________________________________
Dennis Varkevisser
Flexible Engineering Support
<u>www.flexibleengineeringsupport.nl
+31 6 50 68 01 79
</u>
