read function Pattern table
  • August 23, 2024
  • 532 views
I am trying to read a ptb file into pattern table using toolkit. I only find one way to do so is to read the ptb file and then build the element tree and assign the values into the element tree.
Is there any other way it can be done or any sample code to refer how to build element tree of pattern table.
Thank You
Catalina
Community Moderator
August 27, 2024
Hi @Sss4598,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina | PTC Community Moderator
