storing and retrieving array of C stucture into model itself.
ptc-3251077
Hi all,
Does anyone know how to store and retrieve array of C stucture in model itself?
I know it can be done using ProExtdataSlotWrite() and ProExtdataSlotRead() API by using the 'PRO_STREAM_TYPE' data type.
But i dont have any refereance of how to do it. Does anyone can provide me some reference or example for this?
TIA
-Vaibhav Gharat
Hello!
This is my used code and works fine:
CMtkErr CMtkMdlHistoryCtrl::ReadData(ProMdl Mdl)
CMtkErr err(MTKTHROWERROR_ON);
try
ProExtdataErr ExtErr;
if (Mdl == NULL)
err = PRO_TK_BAD_INPUTS;
// Load external data
ExtErr = ProExtdataLoadAll(Mdl);
if (ExtErr != PROEXTDATA_TK_NO_ERROR) throw ExtErr;
ProExtdataClass ExtdataClass;
ExtdataClass.p_model = Mdl;
wcscpy(ExtdataClass.class_name, MTKMDLHISTORYCLASS);
ProExtdataSlot ExtdataSlot;
ExtdataSlot.p_class = &ExtdataClass;
ExtdataSlot.slot_id = -1;
wcscpy(ExtdataSlot.slot_name, MTKMDLHISTORYSLOT);
int DataType, DataSize;void *Data;
ExtErr = ProExtdataSlotRead(&ExtdataSlot, KEY_BY_NAME, &DataType,
&DataSize, &Data);
if (ExtErr == PROEXTDATA_TK_NO_ERROR)
MtkMdlHistoryEntity *Entities = static_cast<mtkmdlhistoryentity *=">(Data);if (DataType == PRO_STREAM_TYPE)
int Count = DataSize / sizeof(MtkMdlHistoryEntity);
for (int i = 0; i < Count; i++)
m_pData->AddEntity(Entities[i]);
ExtErr = ProExtdataFree(&Data);
return err;
catch (ProExtdataErr &ex)
//MtkMsgBox(ProTestProAppdataErr(ex), "ProExtdataErr", MB_OK | MB_ICONSTOP);
MtkDisplayMsg(ProTestProAppdataErr(ex), MSG_ERROR);
return PRO_TK_NO_ERROR;
catch (CMtkErr &e)
e.SetClassAndFunction("CMtkMdlHistoryCtrl", "ReadData");
e.DisplayError();
return e;
CMtkErr CMtkMdlHistoryCtrl::WriteData(ProMdl Mdl)
try
// Initialize external data
ExtErr = ProExtdataInit(Mdl);
// Register class
ExtErr = ProExtdataClassRegister(Mdl, MTKMDLHISTORYCLASS, &ExtdataClass);
if (ExtErr = PROEXTDATA_TK_CLASS_OR_SLOT_EXISTS)
else
throw ExtErr;
// Create slot
ExtErr = ProExtdataSlotCreate(&ExtdataClass, MTKMDLHISTORYSLOT, &ExtdataSlot);
else
throw ExtErr;
ExtErr = ProExtdataSlotWrite(&ExtdataSlot, KEY_BY_NAME, PRO_STREAM_TYPE,
sizeof(MtkMdlHistoryEntity) * m_pData->GetCount(), m_pData->GetEntities());
return err;
catch (CMtkErr &e)
e.SetClassAndFunction("CMtkMdlHistoryCtrl", "WriteData");
e.DisplayError();
return e;
Function : ProTestProAppdataErr
Purpose : Display error message
char * CMtkMdlHistoryCtrl::ProTestProAppdataErr(ProExtdataErr err)
switch(err)
case PROEXTDATA_TK_NO_ERROR:
return("No error");
case PROEXTDATA_TK_INVALID_OBJ_OR_CLASS:
return("Invalid object or class");
case PROEXTDATA_TK_CLASS_OR_SLOT_EXISTS:
return("Class or slot exists");
case PROEXTDATA_TK_NAMES_TOO_LONG:
return("Names too long");
case PROEXTDATA_TK_SLOT_NOT_FOUND:
return("Slot not found");
case PROEXTDATA_TK_BAD_KEY_BY_FLAG:
return("Bay KEY_BY flag");
case PROEXTDATA_TK_INVALID_OBJ_TYPE:
return("Invalid object type");
case PROEXTDATA_TK_EMPTY_SLOT:
return("Empty slot");
case PROEXTDATA_TK_BAD_DATA_ARGS:
return("Bad data arguments");
case PROEXTDATA_TK_STREAM_TOO_LARGE:
return("Stream too large");
case PROEXTDATA_TK_INVALID_SLOT_NAME:
return("Invalid slot name");
case PROEXTDATA_TK_ERROR:
return("General error");
default :return("**UNKNOWN STATUS**");
