How to create leader note in the drawing ? Same as in this picture.
Please help me.
Thank you so much!
@ttathanh wrote:
I can create drawing symbol same as this picture but i don't know to fill black backround in circle.
Please help me.
Thank you so much!
oh yes ... setting background looks problematic. I can use Hatch/Fill command to fill circle with color. Unfortunatelly Creo does not enable me to define that note containing A letter always appears above the filled area. So this method is therefore not applicable.
You can create fixed symbol (this means you cannot set letter displayed in it) using following method.
1.] create part ... letter is cut in cylinder, x-section is defined
2.] place the part's view into temporary drawing
3.] apply Convert to Draft Entities command
4.] use resulting 2D geometry to create drawing symbol
you have to create drawing symbol corresponding to your request.
Please help me.
Thank you so much!
Please help me.
Thank you so much!
Thank you so much!
I try do it again.
