I've created a sketch of a simple rectangular xsec with a fillet in one corner. I've placed points along the fillet as well as the other corners and would like to export those points to a file (.xlsx, .txt, .csv, etc.) for use in another application. Is this possible? Any workarounds?
Robert,
You may try exposting the file as IGES with Datum Curve and Points and later import that in Creo and export to PTS. As:
1. Export file as IGES
2. Check only Datum Curve and Points
3. Change the extension of exported file as .ibl.
4. Create new part and import the points from IBl using, Point ? Offset Coordinate System > Select CSYS > Import > Slect the IBl file
5. With in Datum point dialog use Save and save as new file
6. Exported file will have X, Y and Z, now saved file can open in text
