Control reference dimension parentheses via Drawing Setup, not Config
proed
1-Newbie
Creo and Pro/E have a config option, shown below, that controls the display of reference dimensions in drawings.
I propose this is controlled via Drawing Setup/DTL per drawing - instead of config.  The main reason is: CAD Workers produce viewables of drawings, all with the same config file, however some product lines wish to show 'REF', and others wish to show ( ) around reference dimensions.  If the option was embedded in each drawing via DTL (like text, arrows, etc) - this would be possible.  Currently you must choose one or the other...
Thanks for reading!
parenthesize_ref_dim
no*, yes
encloses reference dimensions in parentheses. if set to no, the reference dimensions are followed with the text "ref."
0 REPLIES 0
