Creo 2 Parametric - Auto regen
dgschaefer
When I change a feature dimension in Creo 2 (select feature, RMB and select edit) Creo pauses, regenerates the model and updates the screen.  Kinda neat except the model isn't really regenerated, it only looks like it is.  Once I'm done I need to regen it again (or if I hit the magic left mouse click, sometimes it regens itself.  Soemtimes not, but that's another discussion.)  If the change is significant that means staring at my screen for a long time twice to wait for Creo do regen the same change.  And if I need to change 2 dimensions, that means 3-4 regens, 3 dims = 4- regens, etc.
While it's nice to see the change previewed, I'd like to turn it off since it's only a preview and not a real regen adn simply wastes time.  What's the config option to do that?
LinkedIn
Did a search at ptcuser.org and found this discussion (PTCUser membership required) with the answer:
enable_auto_regen no
LinkedIn
LinkedIn
