I'm using Creo View Express 3.0 to open drawings (created by Creo 2.0). However, in some sheets, the views are missing, just only notes or dimensions are shown.
Please help.
DoVan
in config.pro file the following option must be set:
SAVE_DRAWING_PICTURE_FILE EMBED
Then ... if drawing is saved, then Creo 2.0 put specific graphics data into .drw file. This information is used by Creo View Express 3.0.
So my suggest is:
MH
Hello Martin,
Thank you very much for your help. However, my config.pro file has already set that way.
save_model_display shading_lod
save_drawing_picture_file embed
Anything else you can think of ?
DV
I am sorry I do not have any other tip ...
It looks like the problem is related to some drawings, only. Maybe PTC Support will be able to give you some advice.
MH
