Creo to IsoDraw
malbright
Creo to IsoDraw
I have searched the forums hoping to find a solution for my issue but have been unsuccessful.
When combining more than one assembly in Creo View 1.0 then exporting as .pvz, the file does not display when I attempt to open in IsoDraw 7.1. Has anyone else had this experience who can offer a solution?
These files appear to open in IsoDraw normally at first - the Product View import dialog appears but when I select OK the model does not appear in IsoDraw - the Objects palette displays my part number identify but when expanded nothing appears besides the Standard and Background layers. No geometry appears - even zoomed out all the way and entirely off the grid - no geometry
If I export an untouched .pvz from Creo View 1.0 it loads and views normally.
Thanks for any assistance,
Mark
Running 64bit Windows 7 Enterprise Service Pack 1.
Hello!
Mark Albright wrote:
...When combining more than one assembly in Creo View 1.0 then exporting as .pvz, the file does not display when I attempt to open in IsoDraw 7.1. Has anyone else had this experience who can offer a solution?...
Can you attach this PVZ file?
My apologies VladimirN,
I am unable to share the pvz file due to confidentiality. I have been attempting to recreate the problem with files I could share but the issue doesn't seem to occur unless the files I'm combining are larger assemblies - which create a confidentiality issue to share.
I am unable to share the pvz file due to confidentiality...
OK.
Try to test this file (in PVZ and PVS formats) in Creo View 2.0 and Arbortext IsoDraw 7.2 - the latest releases.
Thank you VladimirN,
I am currently attempting to upgrade to Creo View 2.0/IsoDraw 7.2. I will attempt to process the files again after I am able to install my upgrades.
