We are currently using Windchill 10.1 and Creo Elements Pro 5.0. I am currently creating a drawing template and need to display the Windchill "Number" parameter on a drawing. However, I am not sure of what call out to use.
I was reading around and if it is right, do is it &PTC_WM_PART_NUMBER? But it says on one of the thread (http://communities.ptc.com/thread/36053) that this parameter is ommited from PROE files.
Can you please advise if that is possible and how to?
Mark
You could use a system parameter &model_name assuming that your filename is same as number in WC. See available system parameters https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS133915&posno=7&q=&model_name&nav=ptcproductgroups||creo||Product+Group||creo^^ptcmodule||
Mark,
I'm not a Workgroup Manager expert but I found the following document that may help:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS18803&source=tssearch
