In some cases when we are using cutaways (local sections) in drawing views, we require to add a new note for the view showing the scale. However the view scale in that note will not be parametric. Is there any way to associate the drawing view scale parameter inside a non parametric note ?? (&view_scale) is not taking when it was put it inside the note.
Old thread, but I just noticed this in the help documentation:
