Cannot get SPR # for update_drawing without shearing data with PTC Support. And getting SPR number can identify by PTC only.
You can find some of the update #'s on the community and on ptc support
But it's all just a guess. And as far as the community helping, without any data or even a description of your problem you will probably not get any real help.
Your best bet is to open a support call with PTC, make sure you have a non-disclosure and get approval if you have government data, and then send your data to PTC to be evaluated.
