How to gove ordinate dimension in a sketch?
simran
6-Contributor
Hello, Good day everyone..
I want to give ordinate dimension in a sketch but I couldn't find a way to do it, I am wondering if CREO allows to give ordinate dimension in a sketch or not. If yes then please guide me how to do that? For time being i have to add ordinate dimension manually in the 3D model not in the sketch. I want to give ordinate dimension in a sketch so that i would be able to use 'Show annotation" command to pick ordinate dimension directly from the sketch. I am using CREO 3.0
Thank you.
rohit_rajan
(To:simran)
There is a baseline option near the normal option in Creo Sketch.
Use this Base line option to give the Zero(0) dimension.
Then select the normal option and select this Zero(0) dimension and then the entity you want to dimension and then center click to place the dimension.
