Limit dimensions unable to edit Tolerance limits
ptc-4644461
1-Newbie
Hi
I am having problems with limit dimensions I wish to be able to set upper and lower limits in the dimension but the option to allow me to edit this is greyed out.
I have taken the time to read a few posts so I know about changing
tol-display to yes in drawing options
I have also changed
Tools > options > tolerance_standard to ISO
I am just a bit lost where to go from here.
Thx.
Capture.JPGHope you can help.
I think that it is because it is an 'added' or 'driven' dimension, you should be able to enter the limts required in plus-minus mode and it will display correctly when you go to nominal.
If you use a 'shown' or 'driving' dimension you will be able to enter the limit tolerances directly.
If you are using limit tolerances you might also want to visit the config.pro option maintain_limit_tol_nominal - the default is no
18 REPLIES 18
I think it comes from:
A) TOLERANCES_TABLE_DIR config options OR if you didn´t specify check
B) start parts
Check FILE - PREPARE - MODEL PROPERTIES - TOLERANCES (click on change) - popup menu apears - click TOL TABLES - MODIFY VALUE - GENERAL DIMMENSIONS
Here you can see and set table with generall tolerances (tolerances for unteleranted dimmensions), for shaft and holes...
In drawing mode try different TOLERANCES MODE (switch limits to plus/minus) - TOLERANCES TABLE = none, than you can write your own tolerance.
jcrook
(To:vmráz)
I've added several settings to my config.pro but I still have to go to Files->Prepare->Detail Properties->Details
and change "tol_display' to yes.
I've attached my config.
Could you take a look and let me know what I'm missing or not doing correctly?
I have tol_display yes and and the tolerance_table_dir set with directory location.
I have an inch and metric config. The inch is attached.
Thank you,
Jay Crook
mslotty
(To:jcrook)
Thank you,
Jay Crook
your config.pro doesn't control detail options. There is a "prodesign.dtl" file that Creo uses for drawings. The tolerance shown setting is in there.  You can save your modified "prodesign.dtl" file wherever your config says it is pulling it from, or you can save a separate one locally and load it when you start a new drawing.
Let me know if this helps or not.
Kenzi
dschenken
(To:jcrook)
I think that entries for directories that have spaces in them have to be enclosed in quotation marks.
tolerance_table_dir "C:\Program Files\PTC\Creo 4.0\M020\Common Files\tol_tables\iso"
mslotty
(To:dschenken)
If you edit your config directly through creo, there is a browse option.  You have to select the file you want it to load.  You can also directly set the directory (folder) path of (for example) start parts or drawing formats this way.  I have never needed to manually type in a filepath, so I can't say whether or not you need the quotes around it at all. I have personally never had to, since i route through the "browse" function, then either copy and paste my filepath in, or manually go to the location I am seeking.
karthik3
6-Contributor
(To:vmráz)
Even I am having  the same issue. But, as you said i can't even my Tol_Tables option in model properties is grayed out. Please, help me finding a solution.
Thanks in advance
karthik3
6-Contributor
(To:vmráz)
Thanks in advance
jcrook
(To:karthik3)
Hi Karthik3,
Attached is a MS word doc explaining how I got the tolerance display to work in Creo 4.0.
If you have any more problems let me know.
Jay.
karthik3
6-Contributor
(To:jcrook)
Crook,
Thanks for the information. But my question was how do you edit limits? while working on it, I found the way to edit the value of limits. We need to go to plus-minus option in tolerance and give values. As I am new to creo, It's been a tough task for me.
Once again thanks for helping me out.
jcrook
(To:karthik3)
Hi Karthik3,
I've updated the word doc I attached last night with the additional instructions.
Jay.
karthik3
6-Contributor
(To:jcrook)
Thanks for that.
najib
(To:vmráz)
Thank you. Your solution saved my last day of the year 2021 🙂
JayCrook
(To:najib)
Your welcome najib.
Also, mslotty, above, mentioned that the changes can be saved in a prodetail.dtl file.
Store this in the same directory as the config.pro file and it will load these settings.
Have a great year,
jcrook.
Hi Charlotte
Thx for you help it works with dims generated from Show model annotations but not with dim's added myself odd but this should allow me to complete my work Thx.
Last time I had a work mate who set this up for me I don't remember what he did last time, I was able to manual add a dim then change to limits then adjust the values I required.
Hi all
I am really need to be able to edit limit tolerances on dimensions I have added hope you can help.
Thx.
mslotty
(To:ptc-4644461)
Edit is using the "plus/minus" option, then switch it back to "limits".
It should display correctly.
IE:
Dim in CAD is 0.4, you need a limit of 0.394-0.400
Edit plus/minus +0.00, -0.006, switch back to limits.
moved this discussion over to the Creo forum so that other may benefit.
