sketched point patterns
TracyWillis
Is there a way to have creo calculate the number of pattern instances for holes that are patterned using sketched points?
You can use {0:&PATTERN_NO}X in front of the note to show QTY but that only works if the patterned holes are threaded.
I've been using sketched point patterns a lot lately. They work great if your holes are in random locations, and they're easy to edit.
I just can't figure out how to have creo calculate the number of pattern instances so I can parametrically display the QTY in a drawing note or in front of a dimension
Many Thanks -
Tw
0 REPLIES 0
