Drawing automatic creation
DaniloCalzavara
How can I set the place of the General view in a drawing created automatically from a format?
I got the format and the views right, but these views are out of the right place. I want to centralize them a little bit.
How can I do it?
At the moment it can not be configured.
EFX calculates required scale and view distances and then places the whole thing in the upper left area.
The result looks ok if scale somehow is ok.
As a workaround you can write more allowed scale factors in <efx_install_dir>/configuration/drawing_scale_list.txt
Then the scale becomes not too small and the drawing should fill bigger area of the sheet.
