Questions, comments,concerns or even complaints?
  • November 12, 2010
  • 3 replies
  • 4814 views
If you have questions, comments, concerns or even complaints, post it here!
Here is a list of our products:
Main Products
Knowledge Based Engineering
SmartApps
    I need to Know how to add standard die base library in PDX instead of editing individual plates. Is it possible?
    Hi Rajesh,
    there are two ways to prepare die sets:
    - Create your standard die set once in the plate wizard and use File > Save. You can later on retrieve this setup by File > Open. This information is usually stored in <PDX>\configuration\my_plates.
    or
    - Create the Creo data of your die set and save it to <PDX>\configuration\my_diesets. You can use these templates later on when creating a new project in PDX.
    In PDX 9.0 you have also the possibility to save die sets to in sub directories of <PDX>\components\<unit>\plate and retrieve these in the plate wizard by selecting supplier and size.
      Achim
    Hi Achim
    Thanks for your Reply..
    I want to know how integrate form analysis to PDX, and where I can download that tool.
    Thanks & Regards,
    Rajesh D
    Hi Achim,
    I am asking about BEA (Blank Estimation Analysis) integration in PDX.
    I want to know in EMX how to edit slider angle pin dia and also I want to add misumi sliders. Do you offer any std Misumi Sliders
    Rajesh D
    Is it possible to give space between core plate and cavity plate in EMX, If possible let me know the procedure.
    Rajesh D
