We usually use the Z03 reference (Hasco) as ejector guide, but in the "Assembly Definition"->"Ejector Guide" this type doesn´t appear. Is it possible to add it?
Add the line below to comp_data.txt in folder <EMX>\components\<unit>\guide\hasco. It will be available when assembling ejector guide.
So simple....
Sorry, not working properly. ![]()
The Z03 guide now appears on the assembly definition but when I press ok, It says an error message:
"Cannot assemble the component"
The cut-outs are opened on the plates the guides do not appear.
You´re right, the guide_5 part file was corrupted, I replaced it with the original and now it´s working.
Nice.
Thanks.
Jose
where from i download the expert mold base plz tell me where from i download the expert mold base plz tell me and how can i use this mold base
