Hello.
It is posible to replace or change the type at several profiles at once? For example, preselect several profiles and change the type to new one.
Hi @YaroslavSin,
that is not possible as modify type can have a huge impact on references in the assembly. The multi-ref support is only valid for the modify size functionality.
greetings Sam
Hi @YaroslavSin,
greetings Sam
