I am trying to develop a drawing in which all annotations on all sheets are followed with the suffix "in". Is there a way of doing this without manually entering "in" into each annotation?
Thank you,
DAAAAA
Do you mean adding a postfix to all dimensions of a drawing in Annotation?
Yes sorry I wasn't familiar with the correct terms. I am looking to add a postfix to all dimensions of a drawing instead of having to manually enter "in" after each annotation.
Thank you. If it is for Modeling/Annotation or Drafting, I think I can help with a macro. Please wait a little.
For Annotation, no use of macro, proceed like this:
Edit the properties of one of the dimensions.
Add the postfix " in"
Click on "Copy to ..."
Select only "Fix Texts"
Press key F2 (selection panel).
Click on "Dimension"
Click on "In Drawing"
Click on "OK"
For Drafting, a macro is necessary. If you need, I can do it.
