Creo Elements Direct Express won't open. Get the One Time Activation dialogue box then the proxy server dialogue box, then the request license dialogue box. Get the 72 hour activation code and enter it and it says it is invalid.
Anyone else having this issue??
Okay just started looking for alternatives and tried one last time and was able to get the 72 hour license to work. Hopefully the license with no time limit will start working soon.
Any update on this? Downloaded Creo Elements Direct Modeling Express 8.0 but could not open it up as it was asking for proxy name and port.
Hello NS_10865890
Follow this description
Best regards
Friedhelm
Hello
Can you explain what you did to achieve this?
Best regards
Friedhelm
Hallo Friedhelm
manual 72 h license works now. It is a pain that the lic server is not running anymore at ptc and not clear why
- programm can be still downloaded but doenst works as promised
- no solution to transfer files, even commercial payed would be ok, or reuse the program with local 1 year key is offered
good night ptc
BR
Hello BR_9969714
nice that it works for you but my question was directet to RG_10785686
To RG_10785686
What did you do differently from before when the activation code didn't work?
To BR_9969714
What is promised? If you would like to go to the download page.
https://www.ptc.com/en/products/creo/elements-direct/modeling-express
There you can see under System requirements:
*Internet: Active Internet connection required to run software every 72 hours
Below in the link
https://www.ptc.com/en/products/creo/elements-direct/modeling-express/system-requirements
Internet requirements: Active Internet connection required for product activation.
Note: Product reactivation is required every three days.
That is all we were promised, and unfortunately that is the case at the moment.
To give you an idea of the scale. Price in Germany € 3,280.00 plus VAT.
Subscription /1 year with automatic renewal.
But even there you can't load your data already created with Express.
Best regards
Friedhelm
