After use tool Isometric in Modify tab, I create rectangle and have error like that. Please help me how to do to be normal.
You are probably in isometric mode. To return standard mode type
CS_AXIS ABSOLUTE 0 1 90 1
Do you mean that you get a diamond instead of a rectangle?
Could you please describe a little bit more the error?
