I am trying to create a new format with titleblock & other model details. When the parameters are added in the title block the same is not updated when model is called in the drawing sheet. Kindy help.
Naresh
Are you working with Creo Elements/Direct Drafting and Drawing Manager?
If yes, your references texts should be in the format tb:NAME or tb:SCALE, etc.
