7-Bedrock
May 16, 2025
Why it not show Drawing Creo elements/directs drafting Mixed UI
  • May 16, 2025
  • 2 replies
  • 1090 views
I use Creo elements/directs drafting Mixed UI 20.7 on Lenovo LOQ gaming 2024 having RTX 2025 Nvidia
When I draw any Geometry (Line, Circle, Point, Rectangle,...), I can not see it on display
I had tried to solve by checking Geometry setting, Viewport -> setting, Setup -> show -> Layer. But all fault.
I see that I open Setup -> show -> Layer, change color to White and save. But, when I open again. It is still default with Black. whether is that the cause? What is the way to get ?
Or. Who are know the tips to fix it? Thanks
Try this: Set MEDISPLAYDRIVER=opengl in me10.ini.
7-Bedrock
May 16, 2025
Hi Sir
Can you let me know clearly step by step to access your idea? thank
Community Moderator
May 19, 2025
Hi @NgocNguyen_28,
Anurag
That could be also a change in viewport configuration
Try other settings
