Show Model Annotations are too big when added
TomK_MN
7-Bedrock
have a busy hole pattern, using Show Model Annotations I am adding the datum axes, but they are too big and overlapping. How do you change the size of when they are first added? (I know how to change them manually once they are added).
Click on File > Settings > Auxiliary Geometry,
then double click on the value to change it for new center lines:
http://kotom.eng.free.fr
Hello TomK
May I ask which cad program you are using?
If it is Creo 6 or another Creo Parametric related, then you are here in the wrong forum.
Here you are at Community Creo Elements Direct in the Drafting subsection.
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
