I am working on Requirement documents in PTC integrity 11. I have requirements document in MS Excel. I want to import it to Integrity 11 . As there are many requirement documents. Please help me to know how to import Excel in PTC integrity for making a reuirement document.
Thanks Volker .
Can you pls provide the add-in for the same. I am using PTC integrity 11.
Just chiming in that I've been using Volker's tool (and a few more) and they work perfectly. Should be part of the standard product !
Hi
This is Prakash. I have a similar problem.
1.i have list of defects in excel.how can i import the excel so that my issues can be tracked in Integrity LM .
2.Is there any template format that can be imported through excel that all the defects can be assigned to a person and respected project.
Thank you
you could give the excel integration a try: https://www.ptc.com/en/support/article?n=CS154958&language=en&posno=4&q=excel%20integration&ProductFamily=Integrity
I already did some imports of issues into single items as well as imports of requirements from excel into documents in ILM.
best regards, Jens
