MS Excel Import for Requirements document in Integrity 11
chandesh25
6-Contributor
I am working on Requirement documents in PTC integrity 11. I have requirements document in MS Excel. I want to import it to Integrity 11 . As there are many requirement documents. Please help me to know how to import Excel in PTC integrity for making a reuirement document.
5 REPLIES 5
Hello Chandesh,
For exactly this purpose, I have created a small add-in for the Gateway allowing you to import any Excel data into Integrity Documents.
The loader will create a new Document Item and will add nodes according to your Excel data. It will also respect the section level if defined.
If you are interested, please send me a "personal message" with your email address.
Thank you, Volker.
Thanks Volker .
Can you pls provide the add-in for the same. I am using PTC integrity 11.
Just chiming in that I've been using Volker's tool (and a few more) and they work perfectly.  Should be part of the standard product !
Hi
  This is Prakash. I have a similar problem.
1.i have list of defects in excel.how can i import the excel so that my issues can be tracked in Integrity LM .
2.Is there any template format that can be imported through excel that all the defects can be assigned to a person and respected project.
Thank you
JensN.
(To:Prakash1)
you could give the excel integration a try: https://www.ptc.com/en/support/article?n=CS154958&language=en&posno=4&q=excel%20integration&ProductFamily=Integrity
I already did some imports of issues into single items as well as imports of requirements from excel into documents in ILM.
best regards, Jens
