ThingWorx 8.5 Solution Central and Q&A
No ratings
Challenge: Complex Deployments
-Today deployment of twx apps is challenging due to manual dependency management; little visibility into apps and environments; complexity and slow speed of deployment
Feature Solution Central:
-Automated dependency management
-Centralized app management portal
Value: Rapid scalable deployments
-Accelerate application deployment
-Simple UI-based environment and solution management
-Site-wide visibility of apps and environments
Steps involved:
-Develop projects locally
-Package artifacts and dependencies
-Publish App to Cloud
-Deliver to your ThingWorx environments
-Update to latest ThingWorx
-Connect to Solution Central
-Begin Publishing
-No additional licensing
Q: Does it also package up prerequisite extensions?
A: It doesn’t package or build them, but they are identified as dependencies before publish/deployment. Multiple solutions building modular structure through dependencies
Q: Each published project is packaged as an extension?
A: That is correct
Q: Is it also possible to manage deployment of collection permissions & OOTB entities permission/configuration through Solution Central ?
A: Whatever can be member of the project can be packaged and published
Q: Can we package locally without publish to cloud
A: Yes. Just don't register to Solution Center
Q: How to install a solution offline ?
A: One can package locally and install them as extensions
Q: Is Solution Central a Cloud only application?
A: Yes, but the packaging capability is available in ThingWorx
Q: Do all customers have access to this solution or do they need to have a cloud contract?
A: All customers can access as part of their ThingWorx license
Q: Will customers be able to install their own on-prem implementationn of the Solution Central Web? Is using our cloud required?
A: The Solution Central portal will only be available in the PTC Cloud, but the ability to package is part of the platform and can be done on prem.
Version history
Last update:
‎Sep 26, 2019 02:43 PM
Updated by:
Labels (2)
