Alerts via Anomaly Detection
No ratings
This documents objective is to provide information and links about alerts used for anomaly detection. This document covers following topics:
  • What Is Anomaly Detection
  • Implementing Anomaly Detection
  • Creating an Anomaly Alert and Prerequisites
  • Anomaly Stats
  • Certainty Parameter
  • Video Example On How To Create An Alert for Anomaly Detection
  • Tips and troubleshooting
Anomaly Detection in ThingWorx is implemented via built-in ThingWatcher functionality. ThingWatcher detects anomalies by monitoring a data stream from a device, calculating an expected distribution of data, and validating that the current data point is a member of the expected distribution.
Anomaly Detection is enabled by default in ThingWorx. However, several steps are required to configure the functionality for your specific environment, including the prerequisite activities below.
Configuring Anomaly Detection to monitor a stream of data. For information about setting up Anomaly Detection, view Preparing ThingWorx for Anomaly Detection.
Anomaly Stats
Anomaly Alert Statuses moves through several statuses as it works its way through the corresponding phases.
  • Initialized
  • Calibrating
  • Training
  • Buffering
  • Monitoring
  • Failed
Certainty Parameter
The Certainty Parameter when implementing anomaly detection requires a number of factors to consider. At its most basic, ThingWatcher functionality compares two sets of data, a validation set (collected during the Calibrating phase) and a test dataset (data streaming from a remote device). ThingWatcher tries to determine the likelihood that the distribution of values in the test dataset is from the same distribution of values contained in the validation dataset. The accuracy of the model plays a large role in this determination, but so does the Certainty parameter used for the statistical analysis of the two data sets.
Anomaly Detection Part 1. Create connectivity between KEPServer and ThingWorx Platform.
Anomaly Detection Part 2. Configure Anomaly Alert to bind simulated data coming through KEPServer for Anomaly Detection.
Anomaly Detection Part 3. Viewing data via Anomaly Mashup.
Diagnose and fix the most common issues that may be encountered when working with ThingWatcher. It cannot be stressed strongly enough that you should be familiar with your data including the average time interval between data points, and the collection duration and certainty threshold you specified.
Version history
Last update:
‎Mar 15, 2018 05:08 AM
Updated by:
Labels (1)
Tags (1)
