Watch a video tutorial on utilizing the Mashup Builder to create a User Interface (UI) for your IoT application.
NOTE: The estimated time to complete this guide is 30 minutes
Click the link below to enjoy the video. You may set the video to full screen by clicking the button in the bottom-right.
If you're following along within your own ThingWorx environment, you may wish to pre-download and extract the attached MBQS_Entities.zip file. It will be used in the later half of the video as a backend data simulator.
Create Your Application UI - Video Guide
Congratulations! You've successfully completed the Video Guide - Create Your Application UI, and learned how to:
We recommend the following resources to continue your learning experience:
Capability Guide
Build | Data Model Introduction |
Experience | Object-Oriented UI Design Tips |
If you have questions, issues, or need additional information, refer to:
Resource Link
Community | Developer Community Forum |
Support | Mashup Builder Support Help Center |
