This script finds an existing Expression Rule and applies it to an asset (via asset includes).
Parameters:
import static com.axeda.sdk.v2.dsl.Bridges.*
import net.sf.json.JSONObject
import com.axeda.drm.sdk.scripto.Request
import com.axeda.services.v2.Asset
import com.axeda.services.v2.AssetReference
import com.axeda.services.v2.AssetCollection
import com.axeda.services.v2.AssetCriteria
import com.axeda.services.v2.ExpressionRule
import com.axeda.services.v2.ExpressionRuleCriteria
* ApplyExpRuleToAsset.groovy
* Finds an existing Expression Rule and includes an asset into it.
* @param model - (REQ):Str model of the asset.
* @param serial - (REQ):Str serial number of the asset.
* @param exprRuleName - (REQ):Str name of the Expression Rule.
* @author Sara Streeter <sstreeter@axeda.com>
def response = [:]
def root = [:]
try {
AssetCriteria assetCriteria = new AssetCriteria()
assetCriteria.modelNumber = Request.parameters.model
assetCriteria.serialNumber = Request.parameters.serial
def findAssetResult = assetBridge.find(assetCriteria)
def asset = findAssetResult.assets[0]
ExpressionRuleCriteria expressionRuleCriteria = new ExpressionRuleCriteria()
expressionRuleCriteria.name = Request.parameters.exprRuleName
def expressionRuleFindResult = expressionRuleBridge.find(expressionRuleCriteria)
def expressionRule = expressionRuleFindResult.expressionRules[0]
def expAssets = expressionRule.includedAssets.add(asset)
expressionRuleBridge.update(expressionRule)
response = [
"expressionRule":expressionRule.name,
"includedAsset": asset.serialNumber
} catch (Exception e) {
response = [
faultcode: 'Groovy Exception',
faultstring: e.message
return ["Content-Type": "application/json","Content":JSONObject.fromObject(response).toString(2)]
