SDK Reference Part 4
- November 8, 2022
- 0 replies
- 426 views
Step 5: Java - Events
While connected to the server, you can trigger an event on a remote Thing. The code snippet from the Simple Thing example below shows how to use a ValueCollection to specify the payload of an event, and then trigger a FileEvent on a remote Thing.
Create Event
The two implementations of the VirtualThing.defineEvent method are used to create an event definition ThingWorx Platform.
@ThingworxEventDefinitions(events = { @ThingworxEventDefinition(name = "SteamSensorFault", description = "Steam sensor fault", dataShape = "SteamSensor.Fault", category = "Faults", isInvocable = true, isPropertyEvent = false) })
public void defineEvent(String name, String description, String dataShape, AspectCollection aspects) { EventDefinition eventDefinition = new EventDefinition(name, description); eventDefinition.setDataShapeName(dataShape); if (aspects != null) { eventDefinition.setAspects(aspects); } this.getThingShape().getEventDefinitions().put(name, eventDefinition); } public void defineEvent(EventDefinition eventDefinition) { this.getThingShape().getEventDefinitions().put(eventDefinition.getName(), eventDefinition); }
Queue Event
To queue an event, create a ValueCollection instance, and load it with the necessary fields for the DataShape of that event.
ValueCollection eventInfo = new ValueCollection(); eventInfo.put(CommonPropertyNames.PROP_MESSAGE, new StringPrimitive("Temperature at " + temperature + " was above limit of " + temperatureLimit)); super.queueEvent("SteamSensorFault", DateTime.now(), eventInfo); super.updateSubscribedEvents(60000);
Fire Event
You can send the client a request to fire the event with the collected values, the event, and information to find the entity the event belongs to as shown below. In order to send the Event to the ThingWorx Platform, use the VirtualThing.updateSubscribedEvents method.
Step 6: Java - Services
Create Services
Simply use the ThingworxServiceDefinition and ThingworxServiceResult anotations to create a service. Then, you can define the service as shown in this code:
@ThingworxServiceDefinition(name = "GetSteamSensorReadings", description = "Get SteamSensor Readings") @ThingworxServiceResult(name = CommonPropertyNames.PROP_RESULT, description = "Result", baseType = "INFOTABLE", aspects = { "dataShape:SteamSensorReadings" }) public InfoTable GetSteamSensorReadings() { InfoTable table = new InfoTable(getDataShapeDefinition("SteamSensorReadings")); ValueCollection entry = new ValueCollection(); DateTime now = DateTime.now(); try { // entry 1 entry.clear(); entry.SetStringValue(SENSOR_NAME_FIELD, "Sensor Alpha"); entry.SetDateTimeValue(ACTIV_TIME_FIELD, now.plusDays(1)); entry.SetNumberValue(TEMPERATURE_FIELD, 50); entry.SetNumberValue(PRESSURE_FIELD, 15); entry.SetBooleanValue(FAULT_STATUS_FIELD, false); entry.SetBooleanValue(INLET_VALVE_FIELD, true); entry.SetNumberValue(TEMPERATURE_LIMIT_FIELD, 150); entry.SetNumberValue(TOTAL_FLOW_FIELD, 87); table.addRow(entry.clone()); // entry 2 entry.clear(); entry.SetStringValue(SENSOR_NAME_FIELD, "Sensor Beta"); entry.SetDateTimeValue(ACTIV_TIME_FIELD, now.plusDays(2)); entry.SetNumberValue(TEMPERATURE_FIELD, 60); entry.SetNumberValue(PRESSURE_FIELD, 25); entry.SetBooleanValue(FAULT_STATUS_FIELD, true); entry.SetBooleanValue(INLET_VALVE_FIELD, true); entry.SetNumberValue(TEMPERATURE_LIMIT_FIELD, 150); entry.SetNumberValue(TOTAL_FLOW_FIELD, 77); table.addRow(entry.clone()); } catch (Exception e) { e.printStackTrace(); } return table; }
NOTE: This service will be callable by the ThingWorx Platform.
Call Services
The are two types of service calls that can be made. The first type belongs to the ConnectedThingClient class. This client has methods for processing information where only the parameters for the method is necessary. The other type of call is based on services located on an Entity. For these calls, you must create a ValueCollection instance, and load it with the necessary parameters of the service.
After loading the ValueCollection instance, send the client the request to execute the service with the:
- Parameter values
- Service name
- Timeout setting (in milliseconds) for the service to finish executing
- Information to find the entity the service belongs to
The first type of call can be seen in SimpleClient.java:
InfoTable result = client.readProperty(ThingworxEntityTypes.Things, ThingName, "name", 10000); String name = result.getFirstRow().getStringValue("name");
The second type of call can be seen below:
ValueCollection payload = new ValueCollection(); payload.put("name", new StringPrimitive("Timothy")); InfoTable table = handleServiceRequest("ServiceName", payload);
