SDK Reference Part 9
Step 13: C - Support Other Platforms
If you are using a platform that is different than the options provided in the CMake configurations or in the C SDK configurations, you can add your own computer type.
CMake has its own custom toolchain support that enables you to add your computer to the CMake configurations.
  1. Go to the CMake Toolchain.
    NOTE: The C SDK provides a CMakeList.txt file that contains the setup instructions for the C SDK. Make changes only if you have verified the configurations and compiler information.
  2. Create a CMakeList.txt file based on your OS inside the folder in which you would like to setup your application.
  3. Modify the Platform Configuration section of the CMakeList.txt file to add your personal computer architecture if it is not already listed.
  4. Ensure your configurations are in your application's CMakeList.txt file.
An example of the Platform Configuration section is shown below.
if (PLATFORM)
 if (${PLATFORM} MATCHES "linux-arm")
 set(OS "linux")
 set(ARCHITECTURE "arm")
 set(CMAKE_C_COMPILER ${CMAKE_CURRENT_SOURCE_DIR}/../TOOLS/gcc-linux-arm-cross/bin/arm-angstrom-linux-gnueabi-gcc)
 set(CMAKE_FIND_ROOT_PATH ${CMAKE_CURRENT_SOURCE_DIR}/../TOOLS/gcc-linux-arm-cross ${CMAKE_CURRENT_SOURCE_DIR}/../TOOLS/gcc-linux-arm-cross/arm-angstrom-linux-gnueabi)
 # Set LD_LIBRARY_PATH
 set(Env{LD_LIBRARY_PATH} "${CMAKE_FIND_ROOT_PATH}/lib/gcc")
else ()
 if (${CMAKE_SYSTEM_NAME} MATCHES "Linux")
 set(OS "linux")
 if (${CMAKE_SYSTEM_PROCESSOR} MATCHES "x86_64" OR ${CMAKE_SYSTEM_PROCESSOR} MATCHES "AMD64")
 set(ARCHITECTURE "x86_64")
 set(PLATFORM "linux-x86-64")
 elseif (${CMAKE_SYSTEM_PROCESSOR} MATCHES "x86_32" OR ${CMAKE_SYSTEM_PROCESSOR} MATCHES "i[36]86")
 set(ARCHITECTURE "x86_32")
 set(PLATFORM "linux-x86-32")
 elseif (${CMAKE_SYSTEM_PROCESSOR} MATCHES "armv5tejl")
 set(PLATFORM "linux-arm")
 elseif (${CMAKE_SYSTEM_PROCESSOR} MATCHES "armv[67]l")
 set(ARCHITECTURE "arm-hwfpu")
 set(PLATFORM "linux-arm-hwfpu")
 else () # default to linux-x86_64
 endif()
endif ()
An example of how to work with your OS in your application's CMakeList.txt file is shown below:
add_executable (SteamSensor src/main.c src/SteamThing.c)
target_link_libraries (SteamSensor LINK_PUBLIC twCSdk)
if (${OS} MATCHES "windows")
 add_custom_command(TARGET SteamSensor POST_BUILD
 COMMAND cmake -E copy_if_different "${CMAKE_BINARY_DIR}/$<CONFIGURATION>/twCSdk.dll" "${CMAKE_CURRENT_BINARY_DIR}/$<CONFIGURATION>/twCSdk.dll"
 COMMENT "Copying C SDK dll to example directory.")
 if (${TLS_LIB} MATCHES "openssl")
 # Copy over openssl dll files
 COMMAND cmake -E copy_if_different "${OPENSSL_SSLEAY_BIN_PATH}" "${CMAKE_CURRENT_BINARY_DIR}/$<CONFIGURATION>/ssleay32.dll"
 COMMENT "Copying ssleay dll to example directory.")
 COMMAND cmake -E copy_if_different "${OPENSSL_LIBEAY_BIN_PATH}" "${CMAKE_CURRENT_BINARY_DIR}/$<CONFIGURATION>/libeay32.dll"
 endif ()
endif ()
if (${OS} MATCHES "linux")
 # Copy over openssl libraries.
 COMMAND cmake -E copy_if_different "${OPENSSL_LIB_DIR}/libcrypto.so.1.0.0" "${CMAKE_CURRENT_BINARY_DIR}"
 COMMAND cmake -E copy_if_different "${OPENSSL_LIB_DIR}/libssl.so.1.0.0" "${CMAKE_CURRENT_BINARY_DIR}"
 COMMENT "Copying openssl to test directory.")
 endif ()
endif ()
if (${OS} MATCHES "macos")
 COMMAND cmake -E copy_if_different "${OPENSSL_LIB_DIR}/libcrypto.1.0.0.dylib" "${CMAKE_CURRENT_BINARY_DIR}"
 COMMAND cmake -E copy_if_different "${OPENSSL_LIB_DIR}/libssl.1.0.0.dylib" "${CMAKE_CURRENT_BINARY_DIR}"
 endif ()
endif()
Step 14: Next Steps
Congratulations! You've successfully completed the SDK Reference Guide.
This guide is designed to be used as a reference when developing your application with one of the ThingWorx SDKs.
Learn More
We recommend the following resources to continue your learning experience:
CapabilityGuide
BuildDesign Your Data Model
Additional Resources
If you have questions, issues, or need additional information, refer to:
ResourceLink
CommunityDeveloper Community Forum
SupportC SDK Help CenterJava SDK Help Center
