I'm trying to communicate CompactLogix L-18 ERM QBFC1 (firmware version 20) with Kepware (V6.13) and facing one strange issue.
If I add the tags manually, I'm getting bad quality data in Kepware. If I try to add tags using automatic tag generation, I'm able to get few tags with good quality data but not all the tags present in the controller. Using .L5K file option, I'm able to add automatically all the tags present in the controller but data quality for all the tags is showing bad.
Please help.
Greeting @MR_9624773,
I hope you're doing well.
Thanks for the detailed description. Based on your issue and the latest findings, here are some possible causes and solutions for the bad quality data you're seeing in Kepware when connecting to your CompactLogix L-18ERM QBFC1 (firmware v20):
Causes:
Fixes:
If you have any questions or need further assistance, please feel free to contact us. We're happy to help.
Causes:
Fixes:
