Facing Tag Data updation issue in kepware server. it is taking more then 60 min to update Tag data, As well as some tag data is not updating. all data is coming at PLC level at real time and in commant prompt, i am receiving response within 1 milli sec.
Please take a look at the following article as it may help resolve your issue:
CS292754 - Configuration project performance optimization in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
