How to config the tags to receive XML parameters in the OPC UA server?
TT_10622061
3-Visitor
the data to receive like:
<?xml version="1.0"?>
<MsiMessageContainer xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<messageInstanceId>8edad249-6f54-48b1-0e1k-38999clf08a3</messageInstanceId>
<direction>MES_TO_SF</direction>
<systemId>55</systemId>
<messageType>MsiOrder</messageType>
<messageContext>502</messageContext>
<message>
<MsiOrderParameterMessage>
<messageInstanceId>878af3de-m6e4-447a-a363-cd62b5ccf0ed</messageInstanceId>
<messageId>DOWNLOAD</messageId>
<supplierId>1</supplierId>
<creationTime>2023-02-21 09:21:05,115</creationTime>
<parameter>
<name>Line_2</name>
<dataType>String</dataType>
<value>11/2021</value>
<isQualifier>false</isQualifier>
<acquisitionTime>2023-02-21 09:20:10,668</acquisitionTime>
</parameter>
<parameter>
<name>Batch_Size</name>
<dataType>Long</dataType>
<value>100000</value>
</parameter>
<parameter>
<name>Line_1</name>
<value>06/2020</value>
<acquisitionTime>2023-02-21 09:20:10,638</acquisitionTime>
</parameter>
<parameter>
<name>EquipmentId</name>
<value>11</value>
<isQualifier>true</isQualifier>
</parameter>
</MsiOrderParameterMessage>
</message>
</MsiMessageContainer>
Greetings!
You can use the XML Client Driver to pull in XML data into KEPServerEX then have an OPC UA Client read those tags. You can refer the below manual :
https://www.ptc.com/store/-/media/Kepware-Store/EN/2021/2021-opc-xml-da-client-manual-en.pdf
Mohit
Greetings!
Mohit
