I am creating devices with the same IP and Slave ID and distributing the tags among them. When I create a device in the Kepserver application and modify its properties, the changes seem to be applied after saving. However, when I reopen the device, I see that the changes were not actually applied. However, if I copy a device with the desired properties and adjust it according to the device I tried to modify, everything works fine without any issues. Additionally, some devices like inv_02 and inv_05 constantly fall into "bad" status, losing their connection. How can we resolve this situation?
Please take a look at the following article as it may help resolve your issue:
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
For 2nd issue,
For 2nd issue,
If this driver works like the database driver, you have to disable the channel first, then make the change, then reenable the channel. to make it stick.
