Installed KepServerEX 6.10 and it gets closed automatically when Opened
@paic @slangley @c_lowy
Shashi
Hi @VladimirN ,
Thanks for quick response, but the Article didn't help !!
The issue was, Java 8 was not installed in the PC, which Caused this issue. Once the JAVA 8 JDK is installed and path is configured, issue was solved, KepServerEx is working normally now.
Shashi
Try this tip - "Installation fails with "Installation Wizard Ended Prematurely" error in PTC/Kepware products": https://www.ptc.com/en/support/article/CS335922
Hi @VladimirN ,
Shashi
I'm glad you solved your problem.
