Hi Experts
I getting Bad quality while i am fetching data from OPC UA Server for the below tags, please suggest what type of data need to assign for these.
10262148_P0019_MV_abActiveFaults | ARRAY OF BOOL |
10262148_P0019_MV_MaxStringLength | STRING[255] |
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[0]
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[1]
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[2]
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[3]
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[4]
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[5]
ns=4;s=G_MES.stOpcData.stAlarmingSystem.abActiveFaults[1000]
We cannot read individual elements over UA unless they exist as individual elements exposed as tags in the UA server. If that server has a Boolean Array, we will only be able to request the entire array as a single item reference. Our client driver cannot explicitly ask for an individual element of that array; the target server will most likely reject the request. The same applies to strings. You can only ask for it by name; you cannot specify the number of bytes to read from a string.
Here is the article that has Workaround: https://www.ptc.com/en/support/article/CS325193
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
